Multiple questions about my setup, any input appreciated
#1 I finally got my fuel rails, lines and regulator up and running and preliminarily it looks like I may not able to return enough fuel to the tank through the stock return line (I let off gas pedal while driving, AFR goes into 12s). I haven't tried tuning yet to see if it's a tuning issue, but I will check that tomorrow or the day after. I was able to turn down the fuel pressure at idle to 58 psi (at 1 atm) without issue. With the intake line hooked up, it seems to idle around 48 psi. If I can control the pressure at idle does that mean the return line is adequately sized?
#2) My turbo is 75 mm compressor and 74 mm turbine. 1.0 AR T4 with 4" exhaust to bumper. Based on my time in sig and raceweight estimated of 5k, is this turbo enough to put me in the 10s on a good pass? How much potential HP is there if I hack off the exhaust and just run an open downpipe? #3) I've previously ran my track passes on 315/60 drag radials, which are 29.5 tall installed. I need to get some 15" wheels in 6 lug, and I'm wondering if I would actually be faster with 28" tires if they can hook as well. Gears 4.11. When I crossed the traps last time at 125.9 my rpm was 6413. Some calculations show my converter is slipping a lot (like 25%) which I want to confirm and need to see what parameters to log on EFI live. I have the capability to lock the converter in 3rd gear and my trans is built to handle that if needed. #4) Assuming good fuel delivery (I have 2 walbro 450 pumps going thru the stock 3/8 feed and filter and then into the rails and then into the external regulator), approximately how much power can my 1000cc injectors support on E85 with a base pressure of 4 bar? The flow rate is 114 lb/hr @ 4 bar. |
Do you have both pumps running all the time?
25% converter slip is terrible, who makes the converter? Are you sure its 25% Mine is like 4.2% on top end. |
No, the second pump is activated by my boost controller at 3 psi
The converter is circle D 258 3 disk. It's supposed to be a 2B. I still should have a free restall but I really don't want to have to pull the converter if I don't need to in order to get 10s. |
I would think that stock fuel filter is a restriction when both pumps are running.
I had the 2B in my old 6.0/S475 ECSB for all of an hour. Put the trans in, filled it with fluid, test drove it maybe 3 miles...then proceeded to park it and let it cool back down so I could pull the trans right back out. I could see 25% slip with that converter. Felt that bad under part throttle :lol:
Originally Posted by BlackGMC
(Post 5301350)
Originally Posted by smokeshow
(Post 5301354)
To be perfectly honest, my old PT3600 (single disk) felt better to me than this 2B. But I wanted to go with CircleD because they're local - easier to deal with in case of issues. |
Originally Posted by GMCtrk
(Post 5301363)
Crud. What did you switch to?
I think that's what's happening at the track. I think I'm turning my power into a furnace.
