MSD 2 step
Old Mar 18, 2015 | 12:43 PM
  #21
Choda's Avatar
where are you ordering it from? I would love to play with one of these but i doubt it will help my truck launch any better. I do consistent 1.7 60 foots in my 4x4
Old Mar 18, 2015 | 02:04 PM
  #22
Jake75's Avatar
Probably amazon so I can put my prime acct to use. My 60s have been pretty rough last time I ran at the track best 60 I cut was a 1.9 on slicks with caltracs before caltracs I was 2+
Old Mar 18, 2015 | 07:47 PM
  #23
RS/SS 4.8's Avatar
10 Second Truck Club
Originally Posted by Jake75
I would definitely want to use a toggle switch. Anyone know where I'd tie into the brake signal at on a 2012 gmc sierra? I have all data just don't know what wire
I have the white/blue stripe wire of the msd box tied into a switch then into the trailer brake light harness. Dont have to cut or tap anything and its fused already. I believe the trailer brake light wire under the dash is a thin blue/green with white tracer for 07+ trucks and the harness is taped up in between the OBDII/ datalink connector and the ebrake pedal. The yellow wire goes to a switch then to the msd box.
Old Mar 20, 2015 | 11:07 AM
  #24
Jake75's Avatar
Size:  141.2 KB I think 18 and 34 should work?
Old Apr 16, 2015 | 09:22 PM
  #25
Jake75's Avatar
well guys i finally ordered the 2 step today and it will be here tomorrow (i love amazon prime)! Im workin days until monday so ill have a test video up next week if all goes well!!
Old Apr 20, 2015 | 05:38 PM
  #26
Jake75's Avatar
Got it installed I tested all 6 wires on the brake light switch at the brake pedal...none gave me 12v. So I started thinking and I just ran a wire from the toggle switch to the wire that runs to the trailer hook up and it worked perfect. I could only set the 2 step to 2900 rpm before spinning tires. I built 5 psi at 2900 rpm
Old Apr 20, 2015 | 06:12 PM
  #27
Jake75's Avatar
Just seen rs/ss 4.8 said to use the trailer brake lol would have save an hr if I saw that sooner
Old Apr 20, 2015 | 07:50 PM
  #28
RS/SS 4.8's Avatar
Yup i used the trailer brake wire because i hate splicing into the factory wiring lol. That and nowadays most electronics use ground signals along with 5v for stuff like tailights.
Old Apr 20, 2015 | 08:18 PM
  #29
mdwatts11's Avatar
Dang. Sounds mean. I wanna be like you when I grow up!
Old Apr 20, 2015 | 08:31 PM
  #30
Jake75's Avatar
Yea man made it so much easier. I just stripped back a small section and soldered it and heat shrinked it
Lol I thought it sounded kinda weak personally....it has a 42" magnaflow I had to take off the borla it was getting to loud for the new neighborhood
