MPT70 t70 guys-spool rpm?
Old May 2, 2011 | 12:51 PM
dueces's Avatar
Default MPT70 t70 guys-spool rpm?
Hey guys, My project car is up and running n/a, and I was just wondering after I put on the Masterpower t70, what type of rpm am I looking at having this thing spool at? I have a 4.8L, ls1 cam and intake, and on the street will run 8psi, and track will be 14-15psi.
Thanks
John
Old May 2, 2011 | 01:19 PM
02'Z71ONDUBZ''s Avatar
It all depends on what a/r turbine housing you choose, and what trim inducer wheel it uses. Example, my brother has a .96 a/r P-trim T70 and I have a 1.0 a/r Q-trim T70. His turbo will spool a fair amount quicker than mine on the street. It really depends on what your looking for out of the setup.
Old May 2, 2011 | 01:24 PM
dueces's Avatar
How much more power can you expect from the q trim? I am shooting for low 600's at the wheels, for track duty and around 500whp for the street. I was looking at the basic .96a/r, but if I need more I guess I can go up,
Old May 2, 2011 | 03:07 PM
black00chev's Avatar
Slowest turbo build ever!
Im not sure what turbine foose04 was running on his T70 but Im pretty sure he made over 600/600 with e85 at 15psi on his 4.8L.
Old May 2, 2011 | 06:05 PM
I'm not positive but I think foose was running a PT67... you might have a bit much lag on the street with a Q trim on the 4.8. I didn't see that in your first post. If you plan on increasing cubes in the future it might be worth it, but otherwise you would probably be better off the the .96 a/r P trim. The best advice I could give you would be to ditch your LS1 stuff and pick up a LS6 cam and truck intake. The LS6 cam is cheap and runs awesome with turbos. Unless you are putting it in a small car the truck intake is a better option.
Old May 2, 2011 | 06:15 PM
caddy03pimpin's Avatar
Gears also play a role in spool time. My friend has a T76 with P trim .96 A/R with 4.56 gears on 24" wheels and he is at full boost (8.75psi) at 3200 RPMs
Old May 2, 2011 | 08:04 PM
orange1500hd's Avatar
when i had my 4.8/t70/.96 AR spool time was ok, around 3-3200 for full boost (7 pounds) if your planning on running 15 psi for sure go with the .96 housing
Old May 3, 2011 | 07:48 AM
dueces's Avatar
thanks for the responses guys! Yeah this is in a car (Ford Probe), so I have to have the LS1 intake. I have the cam because it was 25 bucks, I am just in the start of having the car on the road, so there will be improvements, but can there really be that much of a difference from the ls1 cam to an ls6 on boost?
John
Old May 3, 2011 | 09:51 AM
John
Yes. The LS6 cam is a beast of a turbo cam
Old May 3, 2011 | 10:45 AM
dueces's Avatar
That's crazy, I thought it would be too good of a N/A cam to work that well, I'll keep looking and if I can get one for a good price I'll snag it.
So I think I will keep with the .96 P trim, and I plan on running a water to air intercooler, anyone have any good luck with those? I plan to run an Ice bath at the Drag Strip, so along with my E85 I'll have nice 50-60 degree intake temps.....
John
