MPG with Radix?
I'm trying figure out the variables of what people have to see why I can't get any better mileage. 15.2 is the best I have gotten and that is 70% highway running 78mph. I have a bed cover and a RCSB 4.8 with a 3.0 pulley. I am pulling 8-10"of vacume at that speed and my a/f is right around 14.7. 5 speed with 3.73's and 31.8" tall tires (275-55-20's). My timing fluctuates between 25-32 degrees at cruse. I am thinking that my timing is too low. Also to help the problem out we leaned it out below 2800 to the 12.5:1 range while in PE. It did help a little and mainly quit sooting up my bumper. Before it would jump to 10-11:1 as soon as it went into power enrichment. I have heard of people on here getting 22-23mpg with the radix and i'm trying to figure out what i'm doing wrong. If I was getting 17-18 I wouldn't be worried. On average I drive fairly consevatively trying to keep it out of PE as much as possible and only getting on it 3-4 times a tank. Any suggestions would be appreciated. I know cruising slower would help but that is out of the question
Well 20's, supercharger,3.73,Nice size cam, and LT in my opinion doesnt really equal a good gas mileage truck...
Nothing performance wise is really going to help your gas mileage..
This is my opinion though, alot of people will disagree with me!!
15 is good..
I had a supercharger on my truck with 4.10s and a smaller cam and was getting like 10-12mpg on highway
15 is good..
15 is good..
15 is good..
i run approx 90% hiway and get 20.0 to 21.5 driving like you about 77-78 mph.if i romp on it quite a bit it will go down thou but mainly ride on dbl lane roads( interstates) and dont have to haul *** around others....i have not seen anything under 19.0 average a tank full since the radix install.
Have you guys considered inclines in your driving areas? I have a lot of hills in my local area and a heavy vehicle so I end up in boost a lot. PE fueling AFR ratios are not conducive to good mileage!
There are very few hills where I live, so in general I don't go into boost unless I want to. I can set the cruise control and get 17.5 MPG (or so) all day. With 3.73's that number was closer to 20 MPG.
