MP122HH Inlet forward blown3qtr
Old Jul 2, 2008 | 10:33 AM
  #21
blown3qtr's Avatar
Originally Posted by 2005SSR6Speed
That will look much better. That is exactly what I was thinking!
Originally Posted by fastnblu
Blown3qtr, why not soften the lines a wee bit . IMO, maintain continuity on your brkt. You've a combo of curves & straight cuts. I say do the following, try to stay w/ a style. I'm kinda particular that way, but function over form, ya know. Facing brkt, trim a nice radius under where your cables mount. Use curves on the rest too. It'll be easier to smooth out curves, than to use intersecting lines, unless u don't overcut where the 2 planes (or points) meet. Just my .02.
Was moving the harness Ray's idea? Harness layout plays a part in a sano engine bay.
I thought like Joe on trimmin the brkt, but u already replied on the reason why. Trimmin the top in a gradual semi-circle( meaning beefy part is retained @ corners as u need, & thinnest in center near TB) might work. If nothing else, buzz off the lower corners. From the front, it doesn't hide that much, but it prolly bothers u more than us. Lookin good so far.
Not so much Ray's Idea to "move" the harness, but more so as "how" and where, and I don't think I woulda thought of disconnecting the whole harness from the rear O2's, but then we all saw the rats nest I was dealing with before. Alot of that came from adding a little at a time, and I had to run the main harness over the procharger intake. I'm deffinately gonna clean it up ALOT. I'll probably combine several of the added split looms into one larger one.
I think Ill give all of those bracket options a try. But first things first I need to get this bad boy runnin! Thanks for your Suggestions.
Alex
Old Jul 2, 2008 | 11:00 AM
  #22
fastnblu's Avatar
I hope when I install my Radix, I member to disconnect the o2 harnesses. Thanks for the tip.
Old Jul 7, 2008 | 11:28 AM
  #23
fastnblu's Avatar
Well...any updates?
Old Jul 11, 2008 | 08:09 AM
  #24
leftcoast32's Avatar
FormerVendor
Keep up all the great work!!
Old Jul 12, 2008 | 10:21 AM
  #25
blown3qtr's Avatar
Sorry for the lack of updates. It's in and running GREAT! I'm outta town for work right now in Roswell, NM. I drove the truck out here though I have some work to do on the tune but it is running awesome. Still a lil rich under BE. it makes 5 psi almost instantly 30% tps and 3000 rpm. and getting up to about 7-7.5 around 6,000. I'm runnin a 3.2 pulley right now with plans of a smaller one once I get her dialed in. I plan on swapping the pcm with an '02 when I get back home. I am getting some random knock retard that I am pretty sure is false. Plus from the reading I've been doing the '99-'00 OS dont compensate for changes in IAT's very well so VE tuning is a PITA.
On the drive out here it just purred along at 80mph in OD w/ the converter locked. Could pass at 90 w/o a downshift. Runs DAMN GOOD!
I have more pics to update and I will do it soon when I get some time this week.
Old Jul 12, 2008 | 01:35 PM
  #26
FormerVendor
Sounds great!! If you are seeing 7-7.5 with a 3.2 then you can crank it up to 10+ by just changing to a 2.9 pulley. You will see right at 1 psi of difference for every .1" difference in pulley size. Anything over 10 and you will need the 8 groove pulley setup. Keep us posted on the progress.
Old Jul 12, 2008 | 10:40 PM
  #27
supersub's Avatar
congrats!,glad to hear everything going smoothly!Its nice to know you can hop in and drive with no worries.Lets see some more pic"s!
kha4079
Oct 29, 2018 04:38 PM
1989k1500
Sep 29, 2015 10:53 AM
Tuckin15s
Sep 23, 2015 09:35 PM
MOBBN
Sep 22, 2015 08:07 PM
Cakes
Sep 6, 2015 02:57 PM
