Mp112 to mp122 swap using mp112 manifold?
#21
I have the dimensions of both of the blowers if needed. The bolt pattern is not far off but the MP112 manifold cannot be drilled for it as the bolt holes are too close and would break through. I actually was in the process of purchasing an MP112 from Brian @ superchargersonline a few weeks back but pulled back on the decision because of the mounting issues. However, a TVS1900 will bolt right on...
#22
Based on the dimensions below, the pattern is exactly the same. Also, it seems like if using the same snout the pulley alignment will be fine. It is about .5" taller but on the truck application I think clearance would not be an issue. The J-tube however would need some sort of adapter as the "mouth" bolt pattern is a bit different. Again, if someone was handy with CAD and a mill, this should not be all that hard.
#24
At anytime was the MP122 standard when ordering and the MP112 was not offered? If I purchased one in the last two years would have it been a MP122? I'm not home to measure it.
Suburban2500
07-13-2015 09:57 AM
