mp112 from a LQ9
Ok the H2 has a LQ4 motor not a LQ9 the only issue you may run into is the fuel rail adaptor. (99-03 return style) or (04-07classic returnless) which can be solved by calling david or brian at magnuson. Also the style of fuel pump/booster you will need. If im not mistaken the H2 kit has a different style adapter for the air box than the truck. So you will need that as well. other than that its all the same.
