Motor mounts...Stock? Aftermarket?
Old Oct 19, 2018 | 12:47 PM
redhotev1's Avatar
Default Motor mounts...Stock? Aftermarket?
What are yall using for motor mounts with these turbo systems? Stock? Poly? Solid? Custom?
I'll be putting in an LS1 aluminum block, VSR 78/75......shooting for 10's. if stocker are holding up, then I'll get a set of them. I know on my old 86 truck, the brand new rubber mounts lasted about 2 minutes until I pulled them apart with the boost.
Thanks
Old Oct 19, 2018 | 12:53 PM
ILuvJDM's Avatar
Solid or Poly, and get them from Atomic Performance
/Thread
Old Oct 19, 2018 | 01:55 PM
arthursc2's Avatar
My stock ones have gotten me through everything including 12psi and 180k.
I dont like the idea of solid. If poly is the only available option, thats what I do.
Old Oct 19, 2018 | 02:06 PM
smokeshow's Avatar
Mod with training wheels
Never used anything other than stock.
Old Oct 19, 2018 | 02:11 PM
1FastBrick's Avatar
Custm2500's Rude Friend
that's cause your junk is slow...
Old Oct 19, 2018 | 02:23 PM
smokeshow's Avatar
Which also means your junk is slow. lol
Old Oct 19, 2018 | 03:28 PM
1FastBrick's Avatar
So slow it never leaves the driveway...
Old Oct 19, 2018 | 04:35 PM
'pacheMarshal's Avatar
theoretically a solid motor mount would make launching better because there is less torsional flex. I would be curious to see a before and after timeslip.
Old Oct 20, 2018 | 08:12 AM
Atomic's Avatar
I have a gauge for that
The poly ones from Atomic Performance would be my vote!
Old Jan 16, 2019 | 03:17 PM
imma_stocker's Avatar
Poly trans mount with either to keep the tail end straight.
Solid motor mount if clearances are tight and you can't let the motor torque over and hit something.
