Motor mounts...Stock? Aftermarket?
What are yall using for motor mounts with these turbo systems? Stock? Poly? Solid? Custom?
I'll be putting in an LS1 aluminum block, VSR 78/75......shooting for 10's. if stocker are holding up, then I'll get a set of them. I know on my old 86 truck, the brand new rubber mounts lasted about 2 minutes until I pulled them apart with the boost. Thanks |
Solid or Poly, and get them from Atomic Performance
/Thread |
My stock ones have gotten me through everything including 12psi and 180k.
I dont like the idea of solid. If poly is the only available option, thats what I do. |
Never used anything other than stock.
Originally Posted by smokeshow
(Post 5450199)
(Post 5450203)
that's cause your junk is slow...:jest:
(Post 5450207)
Which also means your junk is slow. lol
theoretically a solid motor mount would make launching better because there is less torsional flex. I would be curious to see a before and after timeslip.
The poly ones from Atomic Performance would be my vote! :D
Poly trans mount with either to keep the tail end straight.
Solid motor mount if clearances are tight and you can't let the motor torque over and hit something. |
