A most interesting article on TVS vs KB Superchargers
Old Jan 31, 2010 | 09:28 AM
  #31
06chevy5.3's Avatar
Originally Posted by Jamesbond2509
Pat, the 2.8 is about an inch longer towards the back so some adjustments may be necessary. - you'll also need an 8 rib setup for the 2.5 inch pulley but you wont regret it - the sound is awesome - more of a deeper tone and 25lbs of boost on tap. Just the twin screw core will run you about 800.00 so cost wise not a bad upgrade for the money if you are willing to craft the inlets and outlets. The advantage of an off manifold setup is you can do all the intercooling you want; the 2 stage intercooler im building is starting to look promising. If I can get the IAT's down to around 50F then even 10lbs will rock!
So you had to custom make your inlet an outlet manifolds?
Old Jan 31, 2010 | 08:30 PM
  #32
I fabricated a set of inlets from the corvette kit, modified the existings outlets for an intercooler, ported some areas, and bought the 2.8L air pump from KB. You can do it all under 2K and have 800 ponies capability on tap if your bottom end can take it. Plus you need to be able to weld aluminum or have someone who can.
Old Feb 1, 2010 | 10:06 PM
  #33
06chevy5.3's Avatar
Cool thanks for the info.. its already intercooled and my short block is forged should be able to take it
Old Feb 3, 2010 | 05:10 PM
  #34
You must be bleeding some boost with that cam!
Old Feb 4, 2010 | 06:22 PM
  #35
06chevy5.3's Avatar
Its a blower grind.... I had a smaller cam in there before the engine blew a little bigger than yours, I haven't noticed any boost loss with the new cam
9.5lbs with a 3.125 pulley
The plan is to go with a 10% overdrive crank and 100mm TB and bigger MAF with 4" intake, If i dont get 13-15lbs with that il start workin on a 2.8 setup
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
moregrip
Jul 26, 2016 11:21 AM
blown 04
Oct 2, 2015 07:33 AM
Wrecker 426
Sep 29, 2015 11:00 PM
old motorhead
Sep 29, 2015 08:22 PM
