More vacuum?
Old May 21, 2013 | 06:59 PM
topgun10x's Avatar
What is your setup? Vacuum is going to be largely based off of your cam overlap.
Originally Posted by old motorhead
Yup. That, idle speed, and tune (timing) can make a big difference.
Originally Posted by AKlowriderZ71
Leaking intake manifold gaskets will cause you to have low vacuum readings at idle. On a scan tool, the MAF will show low g/sec airflow, and high IAC counts too.
Need to know the OP's cam specs to speculate further....
well a quickie is a p1sc 12.75lbs with meth 4.6 to a 5.0 2valve ford one level above stock cam, stage 2 I believe, 5.4 natural gas heads so I believe they are pretty much stock, 2 core intercooler, and stock intake
it ideals at like 700-750ish according to the tach.
not sure what the timing is from idle from what the tuner put.
not sure if the intake is leaking but there is a hole in the header (collector)
Old May 21, 2013 | 07:17 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
11-12 inches sounds about right for stage 2. Stage 3 is even less....
Old May 21, 2013 | 10:49 PM
AndysC3's Avatar
Mine only gets 10-11" at idle. 750 rpm and 26* timing
Old May 22, 2013 | 07:10 AM
topgun10x's Avatar
so 11-12 in. is fine then. if I was to try to get more then it probably wouldn't make a difference!
GMCtrk
18
Oct 6, 2015 03:48 PM
kmcn47
Sep 17, 2015 01:12 AM
2500ZL1
Sep 12, 2015 03:50 PM
creekrat
Sep 10, 2015 12:59 AM
cousblake11
Sep 9, 2015 06:52 PM
