More Air and More Fuel.. Ow & cool gear!
Old Dec 12, 2011 | 04:06 PM
foose04's Avatar
Default More Air and More Fuel.. Ow & cool gear!
Well Rob at ModularTurbo pulled through and got me a 76/Q/.96 Ball Bearing unit to test out. So far, limited testing seems to back up it's going to do just as he said it would, bring the boost! . After installing it, I took 5 turns out of the boost controller and did a 3rd gear pull. Stayed in it for a good 4-5 second seeing a healthy 22psi and a big smile on my face and then I looked down and saw 12.9 on the air/fuels and the smile went away...quickly got out if it. SO, being way out fuel, I turned it down couple turns to 20psi and then finally to 18 where i'm out of fuel still but safely in the high 11 a/fs.
I'm seeing a lot of FP drop ( w/two 255's) so i'm hoping the new Walbro 400's run at 19v with the Kenny Bell BAP will extend the life of the 80lb's. I'm running them at 60psi base, so they should flow around 93lb if the fuel pressure holds.
Also got some good track gear. Pullover for the lady and tee shirt for me. Next year should be fun!! Wish I didn't deploy in two weeks, but hell it will give me one more reason to look forward to getting home!
Old Dec 12, 2011 | 04:14 PM
03regcab sierra's Avatar
Thats freakin awesome! Like the tee shirt too.
Nice!!!
What does your fuel system consist of now?
On Tarinitup's truck we have 80's on it but with a magnfuel pump and some meth. Your 80's should be able to carrier you pretty far.
Old Dec 12, 2011 | 04:15 PM
Well just I remebered you are on E85...
Old Dec 12, 2011 | 04:41 PM
tarinitup's Avatar
9 Second Truck Club
It's gonna be some cool **** when you go faster. What size line is feeding your fuel rails? Lots of people claim you can make 1000hp on stock but mine petered out once I passed 700rwhp on twin walboros. Just a thought.
milkey57's Avatar
That is sweet! I like the size of that pump too, hope they work out for ya!!
Old Dec 12, 2011 | 04:48 PM
02'Z71ONDUBZ''s Avatar
is that a 3.5" v-band?
Old Dec 12, 2011 | 05:19 PM
gavin2005's Avatar
keep us updated on how those 400's do.i will be ordering 2 of them after christmas.i got 2 little boys that's got a big list for santa i got to take care of right now.
Old Dec 12, 2011 | 05:27 PM
foose04's Avatar
Will do man. The Fuel setup will be, dual 400s with BAP, 8 gauge power wire, 8an feed from tank to rails, 1 to 1 FPR, ls1 rails and factory feed line being used for return line. E85 is good stuff but you need a ton of volume.
Old Dec 12, 2011 | 05:40 PM
foose04's Avatar
3" and 3" d/p.
