Milky oil???
Old Dec 29, 2008 | 02:31 PM
TurboJohn6's Avatar
Originally Posted by WJ MARK
well i also have a coolant leak off the heater core connectors, so that need to be fixed before i can keep an eye on the level
Well then a leak down check will still work if you have the tool.
Originally Posted by KySilverado
There are kits you can buy that will test the coolant for combustion gases present in it. Thats how I diagnosed a very small head gasket leak a few years back with a Toyota.
I heard of them but never used one. Work good then? If so, should be a simple way to check for a leak then.
Old Dec 29, 2008 | 02:33 PM
zippy's Avatar
Two questions. One, what thermostat are you running? In cold weather like you might be seeing your oil may not be getting hot enough. Thick oil will slow spool as well as cause yellowish film at the cap. Where all are you seeing this colored oil?
Old Dec 29, 2008 | 03:16 PM
WJ MARK's Avatar
stock thermostat
running 0w-30 synthetic oil, just coming from the breather hose off the valve cover.
Old Dec 29, 2008 | 03:41 PM
zippy's Avatar
Oh, sounds like a head gasket.
Old Dec 29, 2008 | 04:31 PM
KySilverado's Avatar
Worked fine and easy. Kept loosing coolant. Small amounts. Nothing obvious in the oil, one plug showed small amount of off color. Used the kit to confirm.
Old Dec 29, 2008 | 05:18 PM
charcold-bowtie's Avatar
what codes did it throw.
Old Dec 29, 2008 | 06:02 PM
TurboJohn6's Avatar
Where did you purchase it and how much?
Old Dec 29, 2008 | 06:08 PM
A local auto-parts place. Don't remember how much its been years ago. Wasn't too expensive.
Old Dec 29, 2008 | 06:20 PM
TurboJohn6's Avatar
I will have to check it out. I would like to get one since you say they are not too costly. Thanks!
Old Dec 30, 2008 | 04:05 PM
TG02Z71's Avatar
This milky oil can come from condensation and also blow by through the rings.
My 5.3 has been barfing this crap ever since I hurt it, even though it still runs, idles and gets decent mileage.
