Methanol Pre-Turbo
Old Jul 11, 2012 | 04:50 PM
nonnieselman's Avatar
Default Methanol Pre-Turbo
I was reading over on YellowBullet and suprised alot of the high HP guys are spraying a small nozzle pre turbo.
Says it makes the turbo more efficent?
never seen anyone on here use methanol Pre and post turbo.
Old Jul 11, 2012 | 05:30 PM
Atomic's Avatar
I have a gauge for that
Seeing as how most turbo wheels are aluminum, I wouldnt recommend it...
Old Jul 11, 2012 | 05:33 PM
black4.8's Avatar
there is some benefits to pre turbo, but its very corrosive stuff. i would think it would puddle in the bottom of intercooler. i very small nozzle may work. i just use one nozzle right after intercooler and another 12" from tb.
Old Jul 11, 2012 | 05:35 PM
black4.8's Avatar
i saw a turbo wheel that looked like a grinder got hold of it from meth.
Old Jul 11, 2012 | 05:38 PM
Spoolin's Avatar
GFYS and STFU
You better have a good nozzle too, I cringe thinking about any liquid hitting a impeller spinning at 70,000 rpms.
Old Jul 11, 2012 | 07:13 PM
There has been TONS of debate over this as to whether it will damage the turbine or puddle. The general consensus I found was that you want to have a good nozzle that is properly sized and is pointing directly at the nut on the turbine. As far as puddling, I hear it doesn't do it and no worries about the meth corroding anything. It will be vaporized in the compressor. When I do meth I will be calling Julio at alky control and he will more than likely recommend one preturbine and 2 pre throttle body and that's what ill be doing
Old Jul 11, 2012 | 09:06 PM
quicksilverado's Avatar
Spray water pre turbo and it will not hurt the wheel.
Old Jul 11, 2012 | 09:37 PM
If the spray is fine enough and you spray the correct amount you shouldn't hurt it.
Old Jul 11, 2012 | 09:49 PM
2007chevy5.3l's Avatar
I too have heard of guys spraying water/meth pre turbo. Seems to work just fine for them
Old Jul 11, 2012 | 10:53 PM
Mangled03gmc's Avatar
Baltimore Whore
Guys doing it also with prochargers, but I am with Atomic. Being aluminum, I don't think I would do it.
