methanol ?
Old Jun 8, 2006 | 06:10 PM
Default methanol ?
does methanol allow you to run more boost? Also bye itself does it add hp?
Old Jun 8, 2006 | 06:13 PM
methanol allow you to add more boost and/or timing becuase it lowers the IATs. It can also help out if your injector duty cycle is too high.
Old Jun 8, 2006 | 06:33 PM
parish8's Avatar
single digit dreamer
it will let you run quite a bit more boost than pump fuel alone as long as your compresor has more flow avaliable.
i gained just a little power adding the meth. my guess would be 20hp or so. then pulled some fuel to get it back to 11.5/1 and with that i gained a little more. maybe another 20hp. the big gains are with added boost. i was able to add 200rwhp total once i turned up the boost.
Old Jun 8, 2006 | 07:50 PM
dewmanshu's Avatar
Moderately Differentiated
more so of an octane boost if anything.
Old Jun 8, 2006 | 10:10 PM
dammit, I forgot about the octane boost. Ive been researching it lately cause Im sure it will find its way on my truck before long. Got to wait til I can afford a tranny before I add too much more power.
Old Jun 8, 2006 | 10:39 PM
so i add meth i can add boost? like 3 or 4 more psi?
Old Jun 8, 2006 | 10:42 PM
parish8's Avatar
every set up will be diferent. i was able to add 5psi. i went from 11psi max before KR up to 16psi with the meth. tuning will be required to get the maximum benifits.
Old Jun 9, 2006 | 07:33 PM
to bad i cant upgrade the god damn vortec fuel injection.... unless i get another $1500 together...
Old Jun 14, 2006 | 04:39 PM
seadoo's Avatar
alkcontrol.com
the best meth systems on the market PERIOD!
Old Jun 20, 2006 | 10:02 PM
macs406's Avatar
Does the meth injector need to be before or after the MAF? My MAF is about 3 in. from the TB.
