meth wiring
Old Oct 26, 2008 | 09:05 PM
xxwackerxx's Avatar
Default meth wiring
im sure ill get plenty of ppl tellin me to look it up, apperently im effin stupid cause im pullin my hair out trying to find how ppl wired up there meth kits. i bought it used and it has some t-taps and stuff so im unsure where all the wires go. and i got a green wire and the directions dont even mention a green wire and the vacum line...AAHHH
Old Oct 26, 2008 | 09:26 PM
speedaddict's Avatar
which kit do you have? Vacuum line is easy...off the manifold for boost reference.
Old Oct 26, 2008 | 09:27 PM
1Bear's Avatar
I'm sure there are quite a few people who would try to help you, but first off what kit did you get your hands on?
Old Oct 26, 2008 | 10:24 PM
xxwackerxx's Avatar
its an STS meth kit with a 2 1/2 gallon tank with M10 nozzle...got everything ran but the vacuum and a small black wire with a T tap(not sure if it was a ground, if so i dont know why they used a t-tap?) and a large green wire same thing with the tap(large green wire is at the end of the harness where the red (power) wire connects to the pump ... hope im not confusing anyone with my confusion...
Old Oct 26, 2008 | 10:30 PM
The green wire is for tapping into their boost controller. It doesn't allow the high boost unless the meth is activated. The black wire is a ground. There should be two grounds, one larger one coming off the pump and one ground coming off the top of the pump.
Old Oct 27, 2008 | 06:37 AM
xxwackerxx's Avatar
thanks! i totally forgot about running that wire from the boost controller....yeah i got the 2 grounds on the pump... but about two feet back up the harness from there is another little black wire, its hanging out with the vacuum T.? (another ground?)
bearden86
26
Nov 15, 2015 03:58 PM
turbo6c3
Oct 5, 2015 06:11 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
