Meth while making boost
Old Aug 11, 2008 | 10:09 PM
Casey2323's Avatar
Default 2 step..
Originally Posted by JJ_TURBO
I just install the 2 step, it works goods, I can built boost at 3300 rpm but without the 2 step I need to rev the truck to over 4000rpm to make boost, the weird think is that if I keep pressing the gas the rpms will go up to 5000rpm which I don't know if thats right???
All the way to 5,000 without the 2 step?... its because your against the Converter... and the more power u built the more it wants to drive threw it... you can give bolth a try... I allways set the 2 step about 2-300 rpms under stall speed or sure the rpms of the two step to dial in the boost that you want to leave on... 10psi and 5,000 rpms sounds like Great numbers to leave the Line with... esp with the chassis setup that your running !
Old Aug 12, 2008 | 03:18 PM
JJ_TURBO's Avatar
11 Second Truck Club
Thanks man, I was thinking there was something wrong with the converter, tomorrow I'll be testing the truck I hope it works with the help of everyone here.
Silveradorst07
Dec 31, 2015 12:04 AM
greedygenius
Sep 3, 2015 06:51 AM
JordanH
Aug 8, 2015 07:59 PM
tim wellington
Jul 31, 2015 03:28 PM
lxcoupe
Jul 21, 2015 02:12 AM
