Meth while making boost
Old Aug 7, 2008 | 07:36 PM
JJ_TURBO's Avatar
11 Second Truck Club
Default Meth while making boost
One question, and yes I have search but found different opinions about this. Should the meth start spraying while Im making boost on the tree? I had a problem before, while making the burnout and the meth started spraying it would turn off the truck, the meth was set at 4psi, after I moved it to 6psi and it wouln't spray, problem solve. But what if I want to make 8psi on the tree to launch?
Old Aug 7, 2008 | 07:59 PM
TURBHOE's Avatar
it depends if you have a on/off system or a progressive system. mine works off of injector duty cycle so i can build all the boost i want on the tree. but if you have a straight up on/off then it might give too much juice all at once. i put up a thread about this before but like you said there are alot of opinions on the subject. i have a log from when the wife went last time to the track and she stalled to almost 13psi on the line while spraying meth/water.
Old Aug 7, 2008 | 08:13 PM
dewmanshu's Avatar
Moderately Differentiated
put a window switch in line with it. This way you get both, boost online without drowning out your spark and meth on the run to give you your octane boost.
Old Aug 8, 2008 | 02:03 AM
JJ_TURBO's Avatar
I have the snow performance boost cooler, which activates by boost, start boost which sprays less then full which sprays more, I had set the first stage on 6psi and the second at 10psi. I was told to put a window switch, which would you guys recommend?
Thanks for the help.
Old Aug 8, 2008 | 03:58 AM
stock48's Avatar
9 Second Truck Club
Mine starts to come in @10PSI, and is full by 12. If Im only running 10PSI I have it all come in @9, and I run the small single nozzle.
Old Aug 8, 2008 | 06:47 AM
zippy's Avatar
You cold set it up just like a nitrous system to only come on at full throttle. Combine that with dialing in the boost level and you shouldn't have a problem.
Old Aug 9, 2008 | 11:52 AM
JJ_TURBO's Avatar
Well Im only running 10psi right now so Im gonna set both to start at 9. I want to run 15psi then I'll set one at 12 and the second on 15. hope it works.
Im going to install a nitrous system this week and now I don't know if to use both, meth and nitrous, I want to use the nitrous just for the 60's
Old Aug 9, 2008 | 01:17 PM
stock48's Avatar
9 Second Truck Club
What size meth nozzles are you running?
Old Aug 10, 2008 | 12:08 AM
JJ_TURBO's Avatar
I really don't know, I would need to ask Allen, but I'm going to try it like yours this week and lets hope it works.
Old Aug 11, 2008 | 11:09 AM
JJ_TURBO's Avatar
I just install the 2 step, it works goods, I can built boost at 3300 rpm but without the 2 step I need to rev the truck to over 4000rpm to make boost, the weird think is that if I keep pressing the gas the rpms will go up to 5000rpm which I don't know if thats right???
