Meth Kits, like to see your setup
Going to be adding a meth kit to my 122hh blower, like your imput on brands and setup, and if you can upload a pics of your setup
thanks
thanks
well this isnt final but here is my set up
you can see the dual nozzle's i have in the intake tube right before the iat
here is where i mounted my pump
and here is the converted windshield washer fluid tank to a methanol tank
Alky Controll, Julio has a great kit, immense knowlede and unrivaled customer service. I highly recommend this kit!
Above you can see the pump mounted inside the front driver's side wheel well.
The Meth tank is directly above the pump (replaces washer fluid tank)
To the right of the red plug wires, left of the brake master cylinder you can see the stainless brided cable hooking around behind the blower.
And leading into the intake tube. Pretty much invisible.
The only drawbacks to this kit is the lost capacity of the washer fluid (a small replacement tank is provided in the kit) and the lousy plastic brackets to hold the replacement tank.
Check out Wilde Racings setup. It isn't just sweet looking it is proven.
I'll let him chime in on the details.
https://www.performancetrucks.net/fo...d.php?t=385913
Edit:Link fixed.
Edit:Link fixed.
[/URL]
[/URL]
Yeah, he really pumps the juice to it
i currently have a snow meth kit with two big *** nozzle's. I also use that windshield washer tank to hold the meth and the meth tank to hold windshield washer fluid. That way, when I am low, the low windshield fluid light comes on.
