meth injection?
Old Jan 22, 2006 | 11:45 AM
iwannaraceZ28's Avatar
Default meth injection?
with meth injection how much horsepower increase can u expext, and if your running an intercooled s/c will it lower intake temps? also where the hell is the meth kept in a bottle like nitrous?
Old Jan 22, 2006 | 12:24 PM
Mort's Avatar
Cool
I am not sure if you can directly measure the HP increase with meth. It will likely allow more timing and/or boost and that will mean more HP. It will cool more than an IC alone and can be tuned to keep IATs lower when you need it most while under boost at WOT. It can be tuned to add more fuel when you need it under boost but be careful because if it runs out or the system fails and you are relying on it for fuel you may toast some pistons with detonation.
The methanol, alcohol, water or mixture is stored in a plastic container like a windshield washer container as an example. It is usually put in an out of the way location under the hood and the windshield washer container can be used as an option.
Old Jan 22, 2006 | 12:28 PM
whats a good place to buy these kits and how much do they go for?
Old Jan 22, 2006 | 01:00 PM
04Denali's Avatar
Alkycontrol.com
great customer service
Old Jan 22, 2006 | 04:11 PM
Avsfan's Avatar
Snowperformance.net has a great kit also.
Old Jan 22, 2006 | 11:32 PM
Bad_Apple's Avatar
ALKYCONTROL.com They are really nice kits, I have enjoyed mine so far....
turbo6c3
Oct 5, 2015 06:11 PM
JordanH
Oct 3, 2015 03:59 PM
Wrecker 426
Sep 29, 2015 11:00 PM
old motorhead
Sep 29, 2015 08:22 PM
Justin87gn
Sep 10, 2015 12:06 PM
