meth 5v where did you get yours?
Old Jul 7, 2007 | 09:32 PM
2004SSS's Avatar
Default meth 5v where did you get yours?
im wondering where you guys using stand alone 2 bar maps to operate your methanol system got your 5 v from? i have one from the a/c for my drx 90mm harness but im scared that with another 5v tap i might dilute the signal. any other spots that are easy to get to preferebly near the fuse box. but any recomendations are apreciated.
Old Jul 7, 2007 | 10:48 PM
cyazo6's Avatar
I belive there is a 5v reference on the back of you headlight swicth. Pin 13, gray wire. I am really certian about this but check first.
Old Jul 8, 2007 | 11:22 AM
2004SSS's Avatar
anyone else?
Old Jul 10, 2007 | 02:42 PM
LBSBLOWN's Avatar
Tap into the 5V ref. source at the stock MAP sensor at the back of the Manifold.
Old Jul 10, 2007 | 05:15 PM
2004SSS's Avatar
thanks i found it btw. now i need a solid ignition wire that can handle a pull of 15 amps .
Old Jul 10, 2007 | 06:40 PM
DrX's Avatar
DrX
I just split a suitable circuit in the underhood electrical center with one of these fuse taps/circuit splitters. Don't recall offhand which circuit it was.
Old Jul 10, 2007 | 07:34 PM
350SS's Avatar
I assume this is for the pump? You'd probably be better off using a relay triggered with an ignition hot wire so you don't have to worry as much about voltage drops affecting the pump speed/flow.
Mr. Chainsaw
Oct 18, 2015 08:00 PM
turbo6c3
Oct 5, 2015 06:11 PM
JordanH
Oct 3, 2015 03:59 PM
old motorhead
Sep 29, 2015 08:22 PM
gavin2005
Sep 13, 2015 09:04 PM
