MBRP Duramax exhaust on 1500 Silverado
Wondering if anyone has done this?
mbrp S6026P
Modified the 4" straight through system to work on a RCSB?
Are any of the hangers in the right place?
Are the pipes heavy compared to oem?
Mine is a single turbo...
Thanks
Dom
mbrp S6026P
Thanks
Dom
Truck Sponsor
The clamps are universal and very easy to modify.
The 4" pipe is a close fit between the cross frame section and the bottom of the floor.
I added 1 support strap right behind the cab are to help support the weight. It's a long run from the down pipe to the first stock clamp.
Sound has a nice rumble to it, and if you have any resonating going on you can a simple add J pipe post muffler to remove that.
Another thing I did was oval the 4" pipe in tight areas to gain more clearance.
Truck Sponsor
Didn't compare weight.
Coming off the down pipe the first hanger is at the bed. So from turbo to that point was to far for my liking. So I added one hanger. Simple rubber exhaust type hanger. Thing it was 4.00 at oriellys.
What I don't like about the kit is the clamps are old school U bolt type. So once tightened its very difficult to get the pipes back apart if you ever ha we to drop it.
Jojoman01
24
05-03-2016 05:07 PM
