max potential of twin 52mm turbos
Old Jan 16, 2012 | 06:43 PM
bk_cauley's Avatar
Default max potential of twin 52mm turbos
just curious what you guys think i can make with them. i have fuel covered. stock 5.3 with a ls6 cam and springs. will be going through a th400 with a pretty tight convertor.
Old Jan 17, 2012 | 02:59 PM
caddy03pimpin's Avatar
From what I hear you can go around 800 + rwhp with low comp but I could be wrong
Old Jan 17, 2012 | 03:13 PM
bk_cauley's Avatar
That would be awesome. I will be running stock compression and was hoping for 750. even if i had to push the turbos to the limit.
Old Jan 17, 2012 | 03:20 PM
Atomic's Avatar
I have a gauge for that
look at the compressor map of one of the turbos, find the peak airflow in lbs/min at the highest efficiency island, and multiply by 20. Thatll give you a rough idea. So if its 50lb/hr, itll be 1000hp. Just a shortcut.
Old Jan 17, 2012 | 07:01 PM
bk_cauley's Avatar
If im reading it right, they are good for 5-550 a piece. but it rates it in lb/min not per hour.
Old Jan 17, 2012 | 07:04 PM
Atomic's Avatar
Yea my bad I meant lb/min
kush killer
Feb 17, 2016 09:20 PM
thunder550
Oct 8, 2015 04:53 PM
05GMC4.8
Aug 7, 2015 09:55 PM
03regcab sierra
20
Aug 3, 2015 12:11 AM
