Max Lobe speed of TVS1900?
Old Jul 11, 2009 | 05:11 PM
norris_83's Avatar
Default Max Lobe speed of TVS1900?
I should be getting my TVS sometime soon, and I'm wanting to shift at around 6100-6200rpm.. I'm just worried the TVS will max out?
I've bought the tvs of MCN5, and installed is a 2.8 pulley.. He's sending me a 3.1 that I should be using intially until I build up my engine...
any ideas of ratio calculations?
Old Jul 11, 2009 | 05:14 PM
tarinitup's Avatar
9 Second Truck Club
You won't max out anything at that low of an rpm.
Old Jul 11, 2009 | 05:19 PM
norris_83's Avatar
any idea what the max would be? Right now I've got my shift points set at 6500rpm, the truck loves pulling all the way up till there.. I was hoping it would with the tvs, but just worried something might go wrong
Old Jul 11, 2009 | 08:53 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Stock cam, springs? I wouldn't worry about the TVS, all of the graphs I've seen (including mine) show the HP keep rising all the way, never falling off.
Old Jul 12, 2009 | 03:00 AM
norris_83's Avatar
mast L92, 220/234 .570/.588 116 on PRC doubles.
I'm sure i can keep pushing it, but just want to know it's limit.. IATs are around 70*C over summer.
Old Jul 12, 2009 | 09:07 AM
MNC5's Avatar
Spin the szhitz out of it and have fun.. Perhaps someone else who has run boost on a stock bottom end can add some input but I think you'll be fine with the 2.8 pulley and just over 10lbs of boost with the right tune. I didn't tighten the 2.8 up prior to placing it in the box so you'll need to tighten it up if you decide to leave it on there.
Old Jul 12, 2009 | 12:33 PM
Spoolin's Avatar
GFYS and STFU
People are spinning the larger ones much faster to get their 18psi so I wouldn't sweat it one bit, but if you really wanna know PM brian but he'll tell you the same thing.
Old Jul 12, 2009 | 02:16 PM
SuperchargedSS's Avatar
on a side note, if u wanna sell the 3.1, let me know!
Old Jul 12, 2009 | 02:56 PM
zippy's Avatar
Are you running an overdrive on the crank pulley?
Old Jul 12, 2009 | 03:01 PM
EVILGMC's Avatar
i am running a 2.8 on my tvs1900 to 6400 with stock crank pulley...no issues and 9psi
bearden86
26
Nov 15, 2015 03:58 PM
BlownHD
Oct 3, 2015 12:24 PM
Lthompson
Oct 2, 2015 12:45 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Rockrz
Sep 29, 2015 09:07 AM
