max hp on t-case? turbo guys
what is the most any of yall heard of a AWD T-case taking...im starting to worry about the t-case going to **** and coming thro the cab and hitting my ***..lol thats just my luck..... so i ask what do yall think
From: Where our street cars are faster than your racecars..Mississippi
not sure on yours but i have a friend with a selectable t-case on a th350 in an s10 and he put down 1158rwhp.... and his front end and t-case are stock!! but he only runs on the street
i shattered mine into pieces @ 530 AWHP. it was in first gear from a very slow roll, I ended up having to walk out into the intersection and pick up ring gears and other parts of the t case. it was pretty bad. Livernois had the same problem at about the same hp. I am at the point where i have gone through 3 6L80s and 1 transfer case in about a year so i am looking into a 4L80 with no t case or the selectable one. Unless someone wants to trade me my set up for a duramax/allison haha
so i should not use the AWD t-case. i have a manual shift t-case i could use. but are you saying the t-case will not hold? befor parish ran his 10.91, a good friend of mine ran a 10.92 on a AWD t-case with a turbo 350 trans..lol. so i dont know whinch one to put in the truck....>???
im putting 750 to the wheels through my t case with no problems this is my original case with over 145k on it i would say the trick is to nor kill it making rough shifts but since i break the tires free on shifts all the time i wouldnt worry too much
9 Second Truck Club
Don't know haw much HP but I have been 10.30's @4950lbs on a 1/2 ton autotrack. I blew it up a couple weeks ago trying to see if it would shift out of 4hi @wot
Until I did that it was fine.
i know what you saying...i dont know the diff. in a AWD t-case and a autotrack. i know there is a chain in the autotrack but idk about the AWD..
I'm not sure about the AWD t-case, but the manual shif ones can take some massive horses, seen Diesels making enough torque to ring a built Allison Tranny to bits and pieces, but the stock t-case takes it like a champ
