Max boost for a stock 05 gm truck maf
Been slowly getting everything I need and now I've completed the fuel system added a IAT sensor and bought a 2 bar map sensor. I've got the 10lb spring in and was wondering if that's going to max out my MAF. If so what's a good aftermarket one.
I was coming very close to the max frequency with 6-7psi of boost. However I heard it takes a lot of extra airflow to get the last bit of frequency. My MAF actually blew in half around 7psi so I switched to 2bar SD.
You need to adjust the values that the PCM uses to convert the MAP sensor voltage into manifold pressure. If you use a 2bar MAP sensor without adjusting these values the PCM will think the manifold pressure is half of what it actually is. It might run, but not correctly, and no way should you drive it like this.
