Many Questions Meth/Boost
Old Sep 14, 2005 | 08:52 PM
DrX's Avatar
DrX
Originally Posted by 2004Denali
Try alkycontrol.com,
I was told the Radix does not like water to be run through it, again If I'm wrong someone will let you know.
Mark
What about the methanol/aluminum corrosion issue? Anyboby experienced any damage to the Radix from meth?
Old Sep 14, 2005 | 08:53 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Well if the meth only comes on at a preset boost level, which I will probably set to 6 pounds, then I should only use meth on WOT runs. I don't imagine I would go through that much at a time. I haven't priced it around my area. I'm still trying to decide IF I want it. What temp difference does it make? If ambient is 90* what would IAT be without meth and then with the meth? Do you feel an increase in power when the meth kicks in?
Old Sep 14, 2005 | 09:06 PM
BigBlackAv's Avatar
I also have a Radix and would like some more input on other success w/ meth/water injection on a 5.3 and Radix.
Thanks,
Damon
Old Sep 14, 2005 | 11:49 PM
Mike Oxlong's Avatar
Off the subject a tad, but a lot of people use HEET in the yellow bottle. 98% of it is pure-dee methanol. 2% is "proprietary" (I'm guessing water). If I ever get my damn Snow kit working right, that's what I plan to use.
Old Sep 15, 2005 | 08:06 PM
white lightning SS's Avatar
As far as damage goes I contacted magnacharger and they say it would take a lot of meth to cause damage to teflon coating to rotors, however the teflon is only for noise suppresion. after I got everything dialed right I saw .3 gain at the track due to 20 degrees wot timing 10.5 boost and 128 degree IAT on 90 degree humid day No KR. I run 99.8 % methanol which is washer solvent before dillution which we have in parts at my dealership which also helps w/ cost HA!HA! just mt 2 cents after doing research
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
