Magnuson Supercharger - Belt Keeps Coming Off
Old Jan 14, 2026 | 10:08 AM
  #61
91RS's Avatar
If this was strictly my driver, I might, but this is the family vehicle and I’m not there most times it’s being driven. I need it 100%. I’m still in my return window with Amazon for the 6 rib ATI, so I can return it and not deal with reselling it if I can get the 8 rib quickly.
Old Jan 14, 2026 | 01:37 PM
  #62
smokinlmm's Avatar
I have the innovators 10% overdriven balancer, It helps the chargers come on faster. If your going 8 rib they have a nice setup plus you could upgrade to the overdrive balancer.
Old Jan 14, 2026 | 03:17 PM
  #63
91RS's Avatar
I think I need to stay with ATI because I’ve already drilled the crank twice and don’t want to do it again for the Innovators West pin kit. ATI’s is a 4% overdrive. I’ve also confirmed the hub and AC pulley are the same as the 6 rib, so I can just unbolt the balancer itself from the hub and change it out easily and not have to deal with the crank bolt or pulling the whole thing off.
I’m looking at the Olson Kustom Works pulleys. Theirs comes with 2 idler pulleys and it’s a little cheaper.
https://gimmetheboost.com/products/8...or-truck-fbody
Also not sure if I should go for the Griptec supercharger pulley (and I’m not sure which listing on their site is correct) or just get a normal metal one.
Old Jan 14, 2026 | 03:18 PM
  #64
Earl Cordova's Avatar
Originally Posted by 91RS
.......but this is the family vehicle and I’m not there most times it’s being driven. I need it 100%......
IMO then it should be 100% stock.
Old Jan 14, 2026 | 03:30 PM
  #65
91RS's Avatar
We’re past that even if I take the supercharger back off. I wasn’t doing an AFM delete and putting a stock cam back in it.
Old Jan 14, 2026 | 04:35 PM
  #66
smokinlmm's Avatar
I like my griptec. Really cuts down on the slippage.
Old Jan 14, 2026 | 04:56 PM
  #67
91RS's Avatar
Is the TVS .400 under Magnuson the correct option? I emailed them last week and they haven’t answered.
Old Jan 15, 2026 | 05:56 AM
  #68
smokinlmm's Avatar
He is usually pretty fast to answer. I can’t remember, it’s been 8 years since I ordered it. I remember talking to him though, he called me to talk about my setup. Great guy, he used to work for magnuson. Try calling him.
Old Jan 16, 2026 | 06:33 AM
  #69
I can understand not putting the AFM back in as that makes it more reliable.
Old Jan 25, 2026 | 05:02 PM
  #70
91RS's Avatar
Is anyone here using this 8-rib setup from Olson Kustom Works? It is a lot cheaper than the Innovators West parts. I have already changed the balancer to an ATI 917285 8-rib since ATI confirmed the hub and AC pulley were the same, so I was able to swap it without pulling the hub off. I may use the Innovators West balancer on my 2008 if I go through with installing a supercharger on it since they have more of an overdrive.
8 Rib Converion Kit for Truck/Fbody/GTO – Olson Kustom Works
