Magnacharger and MAF...
Old Mar 30, 2015 | 08:03 PM
a.burkins2010's Avatar
Default Magnacharger and MAF...
I have a 2012 silverado 5.3 and I have just purchased a tvs1900 for it finally. I have a K&N CAI instead of the stock airbox. The intake tubing from the maggie kit has no spot for the MAF to mount. Is there and adapter piece I can get to mount my MAF or should I make a custom intake? Any suggestions to help will be appreciated. If anyone made a good custom piping set up id appreciate hering what you did. thanks.
Old Mar 31, 2015 | 01:29 AM
turbo freak's Avatar
2 bar sd tune....
Old Mar 31, 2015 | 02:42 AM
03sierraslt's Avatar
I wouldn't run SD unless the MAF is maxed and on a 2012 it shouldn't be. Pretty sure someone makes a maf housing. I just forget who.
Old Mar 31, 2015 | 04:17 PM
What does SD mean? My apologies if this is a stupid question. Thanks.
Old Mar 31, 2015 | 04:49 PM
Bluecobra's Avatar
Speed Density - aka MAF-less tuning. I am running it on my truck as I was maxing out the MAF.
Old Mar 31, 2015 | 06:20 PM
The newer pcm's have a greater range that the MAF can operate in.
Old Apr 1, 2015 | 03:45 PM
kbracing96's Avatar
Just get one of these and plumb it in.
http://www.ebay.com/itm/251793087341?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Apr 1, 2015 | 11:38 PM
0235SS93's Avatar
Just built one for a guy this week on the exact same setup. I'll snap pics tomorrow. I took a stock airbox that was busted, and cut just the tube portion the maf sits in off and used rubber couplers to plumb it in between. You want to use a tube close to the same size as the stock tube so that the airflow calculations are correct. Bigger tube means slower airflow for the same given volume, which in turn doesn't cook the maf heating element as fast and makes the ecm think it's seeing less air.
madmann26
Apr 29, 2020 09:17 AM
silverstreak07
Jun 28, 2016 06:29 PM
Avalanche2002
Nov 30, 2015 07:31 AM
scooter k
Sep 16, 2015 10:32 PM
flatblack83
Sep 7, 2015 07:52 PM
