MagnaCharger installed, a few questions??
Old Mar 9, 2009 | 08:24 AM
wkdivr's Avatar
It should flow from the intake manifold-to the coolant tank-to the heat exchanger-back to the intake manifold.
Old Mar 9, 2009 | 08:34 AM
SuperchargedSS's Avatar
Originally Posted by wkdivr
Once you get the intercooler pump running, I would fill the tank to just below the level of the coolant coming in. You DO have the coolant running IN in the top fitting, and the coolant OUT fitting is the bottom one.
correct sir. That is how it is.
Old Mar 9, 2009 | 09:02 AM
Last Call's Avatar
TOTM: January 2007
How did you wire you relay? Did you use your fuel pump wire to turn on the relay?
Old Mar 9, 2009 | 09:16 AM
It was tapped in the location per MagnaChargers instructions. The actual relay pack was prewired by Devin (moregrip). Appeared it just needed to be grounded, tapped, and power connected. I know its getting an ingition because I checked it and when the ignition/accessory is on, the light on my test light pops on. Turn it off, it goes off. It's grounded well. Fuses aren't popped, etc.
Now, the relay setup that grip had has three total relays. Connected to that is the relay setup for the puller fans. The puller fans arent kicking on either, so I am almost 100% sure its definetly a wiring issue, just need to figure out where the weak link is.
Old Mar 9, 2009 | 10:28 AM
fixed the intercooler issue. Loose wire, no biggie. Woulda fixed it last night and saved face by posting here, but I was just too burnt.
The coolant vent pipe is still leaking. It's definetly coming UP from the hole, which leads me to believe that the oring is busted or not seated right.
Hissing didn't happen today upon start up and idle. Only did it yesterday after I test drove it down the street.
Old Mar 9, 2009 | 10:31 AM
wkdivr's Avatar
Good deal!!!!
Old Mar 9, 2009 | 01:13 PM
eh, not really. Don't want to have to pull the blower off to fix the coolant leak...sigh...
Old Mar 9, 2009 | 02:40 PM
T-CARDENAS's Avatar
You normally can't hear the pump running, but you should be able to see flow into the coolant tank.
x2, that´s the way it does on mine
Old Mar 9, 2009 | 03:46 PM
ok, All problems solved!
The coolant leak was from a bad o-ring. Swapped it out and no more leaks. We are golden!
Old Mar 9, 2009 | 05:01 PM
wkdivr's Avatar
Just out of curosity, what/where on the o-ring?
