Magnacharger information needed
Old Dec 29, 2007 | 07:26 PM
stock48's Avatar
9 Second Truck Club
Default Magnacharger information needed
Which charger comes in the kit? Are they all the 122 now, or is that an upgrade? Also are there dealers on hear, or do you buy direct from Magnacharger? Thanks J
Old Dec 29, 2007 | 07:31 PM
nightrunner's Avatar
Mr. Obvious
112 is the standard on most kits but it obviously depends on which kit you get.
i know the smaller kits for I-4s and most V6s are the M90 compressor.
i think i read the new kit for the NNBS denalis will come with the MP122HH but all others come with the MP112 i think
Old Dec 29, 2007 | 07:36 PM
stock48's Avatar
9 Second Truck Club
Thanks for the quick rp. It will be for a 02-04 6.0L LQ4.
Old Dec 29, 2007 | 07:37 PM
Mr. Obvious
def. a MP112 compressor then
Old Dec 29, 2007 | 07:40 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
https://www.performancetrucks.net/fo...p?userid=44662
This guy will hook you up with a Radix!
Old Dec 29, 2007 | 07:42 PM
stock48's Avatar
9 Second Truck Club
How do the IAT's compair at lower boost leavels, like 5-7psi. Would there be any advantage in going with the 122 compressor at that boost leavel? I will be towing 8-10K up long steep grades.
Old Dec 29, 2007 | 07:48 PM
Mr. Obvious
5-7psi shouldnt be bad
i dont see a reason to go to the MP122 compressor
there should be someone else on here that has direct experience with the radix in this situation to add to this
Old Dec 29, 2007 | 09:25 PM
leftcoast32's Avatar
FormerVendor
If you are going to be towing alot and want the most torque with lower boost levels the get a 112 or 112HH. I have found the 112HH to be a great Supercharger for a 6.0. The 122HH will actually have less torque on the bottom end as compared to the 112 or 112HH at the same boost levels.
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
Sbrown06
Jul 9, 2015 09:21 AM
