Magnacharger heat exchanger relay issues
Old Nov 17, 2014 | 07:41 AM
xsports33's Avatar
Default Magnacharger heat exchanger relay issues
anyone else having issues blowing their relay that runs the bosch water pump for the heat exchanger?
it seems like i have to replace the relay every other winter because it stops pumping. first time it happened about 5 years ago i ordered a whole new pump assembly, relay, and resevoir... turned out to be just the relay.
Old Nov 17, 2014 | 08:26 AM
PSM's Avatar
PSM
Mine has been running fine since I installed it in 2008 and my truck is my DD through Northern New England winters. Not sure if you have a bad connection or what. Either way I'd say its not the norm.
Old Nov 17, 2014 | 09:42 AM
xsports33's Avatar
I installed mine in mid '06 and have replaced the relay about 3x already. Never had an issue for the first 4 years, it started when i moved from San Diego, CA to Chicago, IL... i wonder if the cold has anything to do with it. I rarely drive it, unlike you DD, and it has less than 50K on the clock.
thanks for confirming that it isn't normal.
Old Nov 17, 2014 | 10:12 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
If you aren't running antifreeze in your intercooler, just like your radiator, it will freeze. I suspect your pump is damaged, and drawing too much current.
If I'm right, you'll need a new pump and relay to fix it.
Old Nov 17, 2014 | 12:34 PM
xsports33's Avatar
just swapped the relay and fuse and it's back to working like normal.
maybe time to refresh the fluids?
Old Nov 17, 2014 | 01:23 PM
03sierraslt's Avatar
Very likely this, bet your pump is drawing too much.
Old Nov 17, 2014 | 06:58 PM
BlownChevy's Avatar
blownerator
25 Year Member
check your ground
Old Nov 21, 2014 | 06:16 PM
Put a ampmeter on the pump the guys above are correct.
wrb002
Aug 25, 2015 03:56 PM
slowlsx
Aug 13, 2015 08:28 PM
terravast4
Aug 12, 2015 02:07 PM
slowlsx
Aug 10, 2015 05:33 PM
slowlsx
Jul 13, 2015 04:18 AM
