Maggie guys need your help asap!!
Old May 22, 2007 | 12:19 PM
NORCAL TBSS's Avatar
Restricted User
Default Maggie guys need your help asap!!
ok on my 06 tbss with the maggie kit im trying to put a fuel pressure gauge in. Now here the prob. The sending unit is 1/8 pipe thread but the plug on the front of the drivers fuel rail is someting way different. we tried to match it up and cant find the thread pitch etc. i would need it to be a adapter to go from that size to a male 1/8 pipe thread then id use a stainless braided line with 2 1/8 pipe thread females to hook it up
can anyone help???
Old May 22, 2007 | 12:43 PM
BigTex's Avatar
Does yours have a 1/8" threaded plug about 1/2 way down the side of the drivers side fuel rail? Mine did which accepted my sender with no modifications.
Old May 22, 2007 | 01:27 PM
Restricted User
yah it does i guess ill just use that one i wanted to keep that shrader valve in there but thats ok. thanks.
Old May 22, 2007 | 01:58 PM
Holty's Avatar
Notorious BIG
FWIW thats how i installed mine as well.
Old May 22, 2007 | 02:01 PM
Restricted User
UPDATE
i took out the rail shrader valve and yes its 1/8 npt also. now does anyone make a braided fuel line that has 1/8 npt female ends on both sides. I want to mount the sending unit on my firewall because it will look nasty if i mount it on the fuel rail and i have custom covers and will hit them
Old May 22, 2007 | 02:22 PM
BigTex's Avatar
You might be better off getting a 90* fitting to make the sending unit hug the rail.
Are you talking about a standard -2 AN fitting schrader valve, like is on the stock fuel rail? If so, you should be able to find misc parts to hook up a short braided line to your sender.
Old May 22, 2007 | 02:41 PM
Restricted User
the 1/8 npt is the part that threads into the fuel rail. I cant make it hug the fuel rail becuse the covers wont fit.
Old May 22, 2007 | 06:06 PM
Restricted User
ok im gonna get teh adapter 1/8 npt to either -3 an -4 an or -6 an. What an size should i go with??? -3 -4 or -6
Old May 22, 2007 | 06:08 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
-3 will be plenty for fp gauge
Old May 22, 2007 | 07:04 PM
wkdivr's Avatar
PM Blown364. He can get the exact line you're talking about.
