MAF maxed
Old Sep 24, 2008 | 09:42 PM
1989k1500's Avatar
vaccum modulated trans and speed density with 2 bar map.
Old Sep 25, 2008 | 08:54 AM
silver-mod-o's Avatar
Hunt&Fisherator
Yeah, but don't forget if you are running a vac modulated trans with boost you've got to install the trans bypass valve in the vac line. FLT hooked me up for 30 bucks easy fix.
Old Sep 25, 2008 | 09:11 AM
nonnieselman's Avatar
Originally Posted by GMCDee
So should i just run the 2 bar right off for tuning purposes, ill be running the KB kit also just trying to get some hind sight so im not back tracking once i get it installed. Might even get a blackbeartune for intial start then go from there, and get some help from one of the guys on here that lives near by. You running a 2 bar thunder?
That right there is a good idea.. That way you can tweak it with the help of Justin..
Awww ok gotcha 2 bar it is then. I knew i was going to have to run it. Wow i hope EFI has some good repository for me to look into. Thanks guys 18 days left
But you can run the MAF up to a certain limit then let the 2 BAR take over.. Some guys with the Blowers do this cause of how quick it goes into boost..
I went straight to OLSD 2bar MAP.. Do away with your MAF and install a IAT sensor (connect brown and black wires from the MAF to the IAT)
What year is your truck?
Old Sep 30, 2008 | 07:43 PM
GMCDee's Avatar
2000 ecsb
Old Sep 30, 2008 | 07:49 PM
2000 ecsb
I would suggest getting a 2002 PCM.. and if you have EFI live, theres tons of guys that can help you.. I went with OPSD 2bar with no MAF and it was very easy for me to catch on to..
lucas287
31
Jan 12, 2021 06:18 AM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
2plus2
Sep 13, 2015 07:17 PM
JordanH
Sep 12, 2015 12:02 AM
