Maf code
Old Feb 23, 2016 | 07:26 PM
Go5.3tt06's Avatar
Default Maf code
I need some advise. My 2006 Silverado truck is turbo and been driving over since November 2015. Drive awesome and lot of power at 15 psi as crazy. Maf changed to iat. The guy who installed for me. It's call speed density. Maf two wires to IAT ON intake pipe. Emission failed. Say have two code I puzzled because no engine check light. The code p0102 maf circuit signal low and p0103 maf circuit signal high. How can solve the prblem and pass the emission. Mean need tune PCM to get that codes off?
Old Feb 23, 2016 | 08:31 PM
1FastBrick's Avatar
Custm2500's Rude Friend
In order to run speed density you have to fail the maf.
I believe this is why you have the 2 codes.
Old Feb 24, 2016 | 01:31 PM
Go5.3tt06's Avatar
What I do? I need emission pass somehow need clear to codes. If anyone experince.
Old Feb 24, 2016 | 02:03 PM
darkirish63's Avatar
Doesn't sound right to me. The SD tune should only set a P0103 one time and it shouldn't reflect in the OBD II emissions test. If you're running an SD tune, the codes will re-set on the first turn of the key even if you clear them - its in the hard memory of the PCM. Best advice is to find another tuner who can set it up correctly.
Old Feb 24, 2016 | 02:06 PM
BlackGMC's Avatar
Resident Retard
Is your check engine light on?
Old Feb 25, 2016 | 11:02 AM
Go5.3tt06's Avatar
The guy tuner says bring back this sat to fix tune PCM delete one code. Right now I have two codes. But strange no engine light on
Old Feb 25, 2016 | 11:03 AM
Go5.3tt06's Avatar
No cel at all but I scanner it and still able see the code
Old Feb 25, 2016 | 11:05 AM
madmann26's Avatar
So,
What he did was "no mil light" instead of "no error reported".
No mil light will through a code, just not illuminate the CE light.
No error reported won't do either.
He needs to leave them enabled (DON'T uncheck the checkbox) and set them to "no error reported".
Old Feb 25, 2016 | 12:15 PM
George C....'s Avatar
Formerly ScreamingL
You should be able to pass emissions with the maf failed...Been doing this for last decade
Make sure rest of your monitors are set
cfaluck13
Oct 16, 2016 04:05 PM
2WDinSnow
36
May 20, 2016 01:27 PM
Fuelerfire
Apr 6, 2016 04:46 PM
Alvin@PCMofNC
Jan 21, 2016 05:32 PM
tim wellington
Jan 12, 2016 07:32 AM
