maf
Old Feb 19, 2008 | 03:16 PM
dewmanshu's Avatar
Moderately Differentiated
that's what I'd say. Your idle maf regions have been screwed with. yeppers...what zip said.
Old Feb 19, 2008 | 07:26 PM
terravast4's Avatar
I have pulled a p0101 code several times which is MAF performance/out of range. Code usually comes up after a WOT run. Half the time it idles just great others really bad. I even stall sometimes cruising through a parking lot or making really tight turns creeping along or if I have to stop suddenly. rpm's jumping all over the place from 600 to 100 to 300 like it is trying to find the right place. I cleaned the maf, still the same . I even replaced the maf due to the code I thought it might be defective. still the same . I cleaned the TB like three times just to make sure. Ever since I changed the pulley I have had the maf issue.
Old Feb 20, 2008 | 07:31 AM
zippy's Avatar
That's a calibration problem if I were betting on it.
Old Feb 20, 2008 | 08:02 AM
terravast4's Avatar
I am taking it back to the tuner to check things out. I know most people here have no major issues with the MAF just checking though.
Old Feb 20, 2008 | 08:41 AM
dewmanshu's Avatar
there's lots of tuning questions to be had here. Has your tuner adjusted the maximum delta airflow table which helps set the limits for the p0101? How about IAC, just plain idle airflow tables? Unless you have a nasty cam keep idle tables stock IMO.
Old Feb 20, 2008 | 06:24 PM
Blown2300's Avatar
MAF is my prefered method... get that tune fixed and it'll be fine
If its maxing out at WOT and high RPM.. then you need a bigger maf or switch to SD.
Old Feb 20, 2008 | 06:31 PM
BlownChevy's Avatar
blownerator
25 Year Member
Bigger MAF would be my first choice.
Old Feb 20, 2008 | 06:36 PM
old motorhead's Avatar
Where do you get a bigger MAF?
Old Feb 20, 2008 | 06:44 PM
dewmanshu's Avatar
Ligenfelter
Old Feb 20, 2008 | 06:47 PM
terravast4's Avatar
yeah, what do you recommend for bigger MAF?
