Made a couple of Radix alterfications
Old Jan 26, 2006 | 06:26 PM
  #51
14 Second Truck Club
What about using these on an 04 truck that is already DBW? Would the vette TB stll be the choice then? It would be on a SSR intake most likely. Is the only mounting difference the diameter and and extra bolt hole, correct? I think a steo-by-step is in order here......
Old Jan 26, 2006 | 06:29 PM
  #52
TurboGibbs's Avatar
Patience. They have told enough to figure it out but as he said the step by step is coming.
Old Jan 26, 2006 | 06:33 PM
  #53
BigTex's Avatar
Originally Posted by 4.8T
so its tall enough to not have to do all the crap you need with the ls1 swap and it don't funnel down stays big inside. ....
Yes, the SSR manifold does funnel down inside to the same internal diameter as the stock truck manifold. Its nearly identical to the stock truck manifold with the exception of the 90mm flange. One sponsor tested the SSR manifold and said is was good for a couple HP over the stock truck manifold.
Old Jan 26, 2006 | 06:53 PM
  #54
TurboGibbs's Avatar
Old Jan 26, 2006 | 07:02 PM
  #55
moregrip's Avatar
what a rush!
Originally Posted by mjhoward
truck manifolds are not where its at regarding higher rpms
Old Jan 26, 2006 | 07:49 PM
  #56
TURBHOE's Avatar
so is it point less on a turbo project then?? i was reading the other thread on this and the guy was saying that it didn't neck down it was big the whole way threw and thats why i thought it was. https://www.performancetrucks.net/fo...0&page=1&pp=40 post #28
Old Jan 26, 2006 | 09:56 PM
  #57
TurboBerserker's Avatar
I AM A MOTHERF*CKER
The SSR manifold is not a good swap from the truck manifold.
I wouldn't sweat it much, though. Parish runs the stock truck manifold and so do I (at least at present .
A better solution that the SSR mani is the Victor Jr.
Old Jan 27, 2006 | 11:42 AM
  #58
BlownChevy's Avatar
blownerator
25 Year Member
True about the SSR manifold....however the LS2 Vette manifold may be a good choice.
Old Jan 27, 2006 | 12:58 PM
  #59
TURBHOE's Avatar
what about the ls7 intake will that bolt on??
Old Jan 27, 2006 | 12:59 PM
  #60
BlownChevy's Avatar
blownerator
25 Year Member
different intake ports
