lsa or turbo?
Old Nov 1, 2020 | 09:44 PM
greenturtle05's Avatar
Default lsa or turbo?
Hello guys its been a while. Currently i have an 07 nnbs crew cab 5.3, with btr stg 3, 1 7/8 headers, 4:11 gears and 3400 stall. Im trying to decide if i want to go turbo or lsa. I will be doing all of the labor myself. Looking for around 6-650 rwhp. Which would be more cost effective? Is 650 doable with the lsa on a 5.3? I will be running e85 and meth. Thanks
Old Nov 1, 2020 | 10:05 PM
FFDP's Avatar
The price of a used LSA has gone through the roof lately, so the cost to turbo is not that much more.
Gone are the days of a $2000 LSA swap unless you know someone with a cheap one to sell. You are looking at $2,000 just for the blower and a lid. Then add in the $1,000+ for CTSV fuel rail, injectors, fuel pump, sensors etc etc etc. You'd also be pushing that blower hard to make 650whp on a 5.3. A turbo would make that way easier.
Old Nov 1, 2020 | 10:43 PM
arthursc2's Avatar
Chinese turbo and kit with a good tuner is the fastest/cheapest way to make this happen
Old Nov 2, 2020 | 01:38 AM
IIGW's Avatar
5 Year Member
turbo
Old Nov 2, 2020 | 07:22 PM
I was looking at the fahler speed turbo log, wish it came with a crossover pipe. How many of you guys running the on3 hotside?
Old Nov 3, 2020 | 06:01 AM
03sierraslt's Avatar
Trick turbo all the way.
Old Nov 19, 2020 | 12:56 PM
To you all that changed piston ring gap, did you reuse rod bearings or replaced? Also whats the recommended ring gap for a gen4 5.3?
Old Nov 19, 2020 | 02:53 PM
For 650hp just run it.
Old Nov 19, 2020 | 07:06 PM
smokinlmm's Avatar
650 wheel or crank?
Old Nov 19, 2020 | 09:29 PM
arthursc2's Avatar
On gen4 rods it doesn't matter as long as he has the fuel and cooling for it
