LSA Blower on NNBS Pulley Size.
Old Sep 10, 2017 | 12:00 PM
Boosted_nnbs's Avatar
Default LSA Blower on NNBS Pulley Size.
I'm currently running a ported LSA Blower with ported 5.3l Heads and custom BTR cam. I currently have a 2.45 upper Pulley and the truck is making 10 PSI with the stock lower. I want to raise the boost to 15psi. Does anyone know what size lower Pulley I would to achieve these.
Thanks
Old Sep 10, 2017 | 10:00 PM
Haxman2's Avatar
This site has a good pulley combo list:
https://weaponxmotorsports.myshopify...s/news/6826132
To technically reach about 15 psi, you'd need something like a 8.60 or 8.70 lower.
You probably wont be seeing 15 psi on your gauge since you have ported blower / heads, but you probably knew that heh, boost is tricky that way
Hopefully that helps! Cheers
Old Sep 12, 2017 | 12:44 PM
Thanks. Looks like I'll be going to a 8.6 crank Pulley
Old Sep 12, 2017 | 12:54 PM
03sierraslt's Avatar
Are you running a single belt setup?
Old Sep 12, 2017 | 01:59 PM
Factory drive, OWK makes a kit allowing you to use the factory drive
Old Sep 12, 2017 | 02:01 PM
Vortec350ss's Avatar
What does the cam look like?
You can't fit that large of a lower ring on a factory drive set up... itll hit your water pump. The LSA guys get away with is because they are direct drive.
Old Sep 13, 2017 | 10:30 AM
You are correct. Do you have a solution to this problem without changing the whole drive system.
Old Sep 13, 2017 | 11:32 AM
Changing the drive setup is the solution if you use that blower. It’s just not the solution you wanna hear.
Old Sep 13, 2017 | 11:41 AM
A 10% OD balancer. You will get another couple PSI out of it.
ATI sells them if you want to spend decent coin on a nice one.
Any word on what that cam looks like?
Old Sep 13, 2017 | 11:44 AM
ATI makes the best hands down IMO. 10% OD like Rob mentioned should give you another 2-2.5psi, they are 8.25”
