LSA blower cams
I was just curious to see what other guys are running, I'm planning to have custom cam spec to my setup ground. That said, this is my setup:
07 classic RCSB (gmt800)
6.0 LQ4 with LS2 pistons
LS3 823 heads
LSA blower w/ 2.45" pulley
Ctsv 56lb injectors
Aeromotive stealth 340 pump
4l80
Stall not yet decided
Detroit trutrac and 4:10
LS3 823 heads
Ctsv 56lb injectors
4l80
It should run strong! Really strong!
I have a few thoughts... its very likely you run out of injector depending on how hard you push it. As far as a converter is concerned, there are a lot of good options. Yank PT2800 is a good performer, Circle D has good offerings and I would likely go the 265mm route, and Precision Industries makes a great converter.
Personally I found the PT2800 was too loose for my truck. I am heavy though and that makes a big difference. My next converter will be the tightest triple disc PI makes.
I currently have a 9 1/2" 3200 (in my 4l60) from performance torque converter in kennedale tx, a local guy, and will likely try to stick somewhere around there. Don't think a 2800 will be enough for me, my cam is going to be BIG
I flashed my Yank 2800 to 4200 RPM. You will be making a ton more power than you are now... the converter will behave drastically different.
Take a look at the specs in my sig. Our builds are not that different...
