LSA blower cams
Old Apr 14, 2016 | 12:41 PM
FELONIOUS1's Avatar
Default LSA blower cams
What're you guys running?
Old Apr 14, 2016 | 01:07 PM
03sierraslt's Avatar
Are you asking what cam specs do people run with TVS blower?
Old Apr 14, 2016 | 01:10 PM
FELONIOUS1's Avatar
Asking what spec cam guys are running with LSA blower (stock on 09-14 ctsv and zl1 camaro)
Old Apr 14, 2016 | 01:43 PM
That's a TVS1900
Cam specs are largely based on the engine combo and goals. What are you looking for and how much boost do you plan to run on what engine?
Old Apr 15, 2016 | 07:47 AM
SUTTERERMAN85's Avatar
Im running a 214/224 on a 115lsa in my 5.3L with a LSA blower
Old Apr 15, 2016 | 08:36 AM
Vortec350ss's Avatar
That's a TVS1900
This.
We need to know the complete package before we can help with cam specs.
Old Apr 15, 2016 | 09:12 AM
FELONIOUS1's Avatar
I was just curious to see what other guys are running, I'm planning to have custom cam spec to my setup ground. That said, this is my setup:
07 classic RCSB (gmt800)
6.0 LQ4 with LS2 pistons
LS3 823 heads
LSA blower w/ 2.45" pulley
Ctsv 56lb injectors
Aeromotive stealth 340 pump
4l80
Stall not yet decided
Detroit trutrac and 4:10
Old Apr 15, 2016 | 09:34 AM
It should run strong! Really strong!
I have a few thoughts... its very likely you run out of injector depending on how hard you push it. As far as a converter is concerned, there are a lot of good options. Yank PT2800 is a good performer, Circle D has good offerings and I would likely go the 265mm route, and Precision Industries makes a great converter.
Personally I found the PT2800 was too loose for my truck. I am heavy though and that makes a big difference. My next converter will be the tightest triple disc PI makes.
Old Apr 15, 2016 | 09:37 AM
FELONIOUS1's Avatar
I currently have a 9 1/2" 3200 (in my 4l60) from performance torque converter in kennedale tx, a local guy, and will likely try to stick somewhere around there. Don't think a 2800 will be enough for me, my cam is going to be BIG
Old Apr 15, 2016 | 09:58 AM
I flashed my Yank 2800 to 4200 RPM. You will be making a ton more power than you are now... the converter will behave drastically different.
Take a look at the specs in my sig. Our builds are not that different...
