-   FORCED INDUCTION (https://www.performancetrucks.net/forums/forced-induction-159/)
-   -   LSA Blower in 2000 silverado, Can I use LSA Map sensor? (https://www.performancetrucks.net/forums/forced-induction-159/lsa-blower-2000-silverado-can-i-use-lsa-map-sensor-540880/)
embs2001 01-08-2016 11:56 AM
I have been looking at the powerbond 10% overdrive crank pulley and I'm trying to determine how much this will increase boost.
The pulley comes in both 6 and 8 rib and I have no clue at what point the 6 rib will start to slip.
I plan for 12 psi with the Trucker cam and Have no clue what combination of pulleys will work best.
CGCBandit 01-08-2016 01:16 PM
Originally Posted by embs2001 (Post 5334997)
So far so good. Got all of the bugs worked out. I probably have over 1000 miles with the blower now..
Still working with blackbear to get the tune finalized but I must say it is a slow process working with him. I guess he is a busy guy.
I have some long tubes I need to install. I have plans to get a 90mm throttle body (still running the stock truck tb).
I want to replace the G80 with a truetrac.
Ill finish it off with a vinci trucker cam and smaller pulley and call it a day.
Nice, sure would like to eventually see some dyno numbers before and after cam. Would be interesting to see the gains.
embs2001 01-08-2016 01:18 PM
Yea, I really don't plan on having it dynoed before cam, unless I end up a Vengeance racing event or something. I'm willing to bet it is right around or under 400rwhp at my boost level.
Forsure a dyno after cam. Hope to have it all done by summer.
Beatdown Z 01-08-2016 08:46 PM
Have you verified if the intercooler pump is pumping water efficiently? It looks like it's mounted too high.
I just received my order from Jesse. Dude builds some quality stuff!
embs2001 01-08-2016 08:54 PM
Yea, Don't mount it there, I had to move it down by the heat exchanger. Alot better now.
Alco 01-13-2016 08:05 PM
what trans are you running ? I'm gattering parts right now for the exact same thing ! have you considered dirtydingo.com plates to relocate the alternator ?
embs2001 01-13-2016 08:36 PM
4l65 trans.
LSsimple is the way to go for the brackets.
OKW-INC 03-06-2016 05:15 AM
Whats up fellas. Guess its about time I wandered over here.
embs2001 03-06-2016 04:10 PM
The man, the myth, the legend. Whats up jesse!
embs2001 03-06-2016 04:36 PM
Thought I would post some videos I took since having the blower. Wanted to show the guys who are thinking about doing this what a stock 5.3 with the LSA blower can do.
