LS6 vs 212/212 Isky vs 23X/24X custom
Old Aug 9, 2011 | 06:17 AM
slowec's Avatar
Default LS6 vs 212/212 Isky vs 23X/24X custom
Here is the deal . I have the ls6 cam yellow springs and 7.425 pushrods now. The springs are like new( I bought them new).
Are the yellow springs enough to run 10 to 12 PSI ?
Would it be worth the money to go bigger ?
Old Aug 9, 2011 | 07:18 AM
smokeshow's Avatar
Mod with training wheels
Yes it would be worth your money. I got valve float with yellow LS6 springs at 9psi and sucked a valve into the head. Definitely upgrade...
Old Aug 9, 2011 | 05:40 PM
slowec's Avatar
Thats not good news, I am at 8.5 psi on stock springs now
Old Aug 9, 2011 | 06:13 PM
foose04's Avatar
I can only speak for myself, but I've put around 30k on my ls6 spings. I have been as high as 20psi with the MP70 unit, but daily drive at 15psi and and track at 17psi. I shift low though with a 6600 fuel-cutoff. I'm sure theres power being lost due to seat pressure, how much though is unknown. Also worth noting with the 70mm, I picked up 100hp going from 10psi to 15psi, just shows the springs were not a huge factor at that point.
Old Aug 9, 2011 | 07:22 PM
Beatdown Z's Avatar
Laid Back
Is this a thread about which cam or which springs? or both?
I'm going to run Patriot duals(already had them) and an Isky 212 in my turbo truck.
Old Aug 9, 2011 | 07:37 PM
slowec's Avatar
I guess both, I have the ls6 cam yellow springs and 7.425 texas speed pushrods so I am ready to install ...OR should I get stiffer springs since I'll be doing the labor anyhow, Or should I sell this package and go bigger. SMokeshow's post scares me , but foose's post make me think just throw it in there...
Old Aug 9, 2011 | 08:05 PM
old motorhead's Avatar
For a .550 lift cam at 8.5psi, the yellow springs should be fine. Now, that 23x/24x cam is a whole nother ball game. You do realize you're talking about two very mild cams and one honkin' big (for a truck) cam?
Old Aug 9, 2011 | 08:17 PM
slowec's Avatar
but I am going to up the boost SOON .10 to12 or so. I realize the last cam is large, but I run a 6.0 and my truck is a roll up window reg. cab with a roll pan. Its one of those snowball effects, I probably should get better springs, well , if i get better springs, I could get a better cam .... mmmm wonder how big???
I'd like to hear a person with experience say, sell that and get a 215/215, you'll be so glad you did. Or someone say , keep that setup and push one more psi and have the same power.
Old Aug 9, 2011 | 08:48 PM
smokeshow's Avatar
Peace of mind is worth more than pieces of an engine, IMO. Not trying to scare you, but check out this pic if you're curious what results from floating valves..
http://i271.photobucket.com/albums/j...s/IMG_1205.jpg
Granted, I ran the LS6 springs for like 9 months and probably 6k miles beating on it all the time with no issues. But my experience tells me not to skimp just to save some cash, no matter how small the savings. Who knows? Maybe I got a bad batch of springs.
Old Aug 9, 2011 | 09:07 PM
gavin2005's Avatar
why don't you get pat g to spec you a cam(cost 25 bucks) and he will recommand which springs and pushrods to buy?
