LQ9 and boost questions
Old Sep 22, 2008 | 04:05 PM
JeevesRules's Avatar
Default LQ9 and boost questions
I just recently purchased an lq9 and was wondering what i would be up against upgrading from my little 5.3 i have in there now.
I have 2 60-1 garret turbos with .81 exhaust housings
a medium sized front mount 2 into 1 with a 25x3.5x7 core
60 lb motrons
was thinking of running a victor jr with a 90mm (i already have the 90mm tb)
tial 44mm wastegates
and a 50mm bov
am i on the right track or should i budget for some other things while im at it?
looking for 550+ on pump will it be cabable?
Old Sep 22, 2008 | 05:03 PM
Wilde Racing's Avatar
How do I change this text
550 will be very easy, thou i think those exhaust housings are a bit on the big side.
What about the trans?
Old Sep 22, 2008 | 05:42 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
What wilde said.
Don't push it paste 10-12psi and you're fine (good tune caveat here -- no mail order!)
All the .81's will do for you is mush the spool.
I'd go to .48s
Old Sep 22, 2008 | 06:27 PM
i have a 3600 stall anti ballon plated tci converter. i was thinking of running a 400 turbo instead of my th350. im also sold on putting smaller gear ratio. i have a 4.56 now might jump down to a 3.73 maybe even a 3.42. not sure yet.
Old Sep 23, 2008 | 03:12 PM
turbo 400 would be my choice of auto shifty boxes...
Old Sep 23, 2008 | 07:29 PM
1BADAZZSS's Avatar
Are you hrydoboost or vacuum boost on your brakes? This will also help with trying to brake boost. Downfall to vacuum boost is that it will override your brakes. Might also have to look into doin dual intank fuel pumps if your wanting 550+hp. Correct me if I am wrong but a single walbro 255 is only rated to 500hp....
Old Sep 23, 2008 | 09:25 PM
You can clear 500 with one single.. if he is going to spray meth he an push it way further
Old Sep 23, 2008 | 09:34 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I run a single in-tank 255lph pump with the Magnavolt and a bit of meth.
Old Sep 24, 2008 | 02:02 AM
thunderwagen's Avatar
Your list looks good so far....housings are kinda big but it will do work. I have run 11# daily for over a year and not blown anything up so you should be fine. Seems like 12 is the tops for boost on the stock long block, so I wouldnt go over that.
Old Sep 24, 2008 | 07:19 AM
hellbents10's Avatar
LS1Tech Sponsor
Housing in the .6ish range would work a little better for power output under 800fwhp or so. With good fuel I have turned a lq9 up to 825whp. On pump keep it at or below 500-550whp though.
