lopey turbo cam??
Old Dec 21, 2011 | 09:43 PM
cfaluck13's Avatar
Default lopey turbo cam??
What kind of specs would create a lopey sounding idle and still be efficient for a turbo. for a otherwise stock 4.8
Old Dec 21, 2011 | 10:11 PM
stock48's Avatar
9 Second Truck Club
How lopey? What size turbo, and converter? How much boost?
Old Dec 21, 2011 | 10:13 PM
Jake99's Avatar
Well I got a 212-212 562 lift 112lsa +5 for my 4.8, should know in a few weeks how it will idle but I know its going to have some lope to it, anything with small dur. and a tighter lsa will work good for boost cause over lap aint a problem. Remeber you dont need a big cam to make big power the turbo will hold it back more then the cam will, a bigger better flowing turbo with and a smaller tight lsa cam will spool just as good as a small turbo with a big cam but make more torque when the boost comes in.
Old Dec 22, 2011 | 06:35 AM
cfaluck13's Avatar
Enough to notice, Ive just rebuilt my 4l60e and put a vigalante 3200 in it. Im on 7lbs now with a mp70 but plan on turning it up to about 12 soon
Old Dec 22, 2011 | 06:36 AM
slowec's Avatar
My stock48 spec'ed isky 212 has a lil chop in my lq4. Gives it a nice lil noise at the red light.
Old Dec 22, 2011 | 07:38 AM
myth's Avatar
I have a custom gring 218/222 on a 111lsa. It has a very nice chop. I dont know how good it will be for a turbo cam but I will find out.
Old Dec 22, 2011 | 09:36 AM
Mangled03gmc's Avatar
Baltimore Whore
Durations, lobe profile, lsa will make the chop.. You can get away with a tighter lsa turbo cam and still notice a decent difference
Old Dec 22, 2011 | 10:51 AM
stock48's Avatar
9 Second Truck Club
A 212/109 ~110 lsa Isky would chop and work pretty good in a 70mm 12psi 4.8L. The problem with high psi and tight lsa is it can detonate easier.
Old Dec 22, 2011 | 11:49 AM
carbongmc's Avatar
Geoff at EPS spec'd my cam. 226/222 on a 112+2 LSA. I can honestly say, it chops. I could pass mine off as a cammed NA motor with no problem.
Old Dec 22, 2011 | 12:22 PM
cfaluck13's Avatar
Any sound clips? If i dont find anything I might just stick with a ls6 bump stick and keep it more sleeper-ish
