Loosing boost at WOT
Old Nov 1, 2024 | 01:05 PM
xsports33's Avatar
Default Loosing boost at WOT
Hey guys! it's been a long time seen i've been on the forums - life, kids, etc.. i won't bore you with the details.
This just started to happen in the last few months, can't say exactly when since the truck has become my weekend warrior and i don't go wide open very often. I'm losing all boost at WOT and running super rich, it just bogs down. I used to get 7-8 psi at WOT and the truck would pull hard through all gears. Now at partial throttle 50-70% I get around 3-4 psi, but as soon mash the pedal boost drops to 0, FPR goes to 10.0 or lower (bottoms out at 10) and the truck completely bogs down. Happens every time i go WOT from a complete stop or rolling/cruising. I've had the same tune for 5+ years, haven't changed anything. Everything was working cherry up until a few months ago. I replaced the bypass actuator thinking i was loosing boost for that, but no change after replacement. I replaced the belt as well thinking it was belt slip, but same issue after new belt installed.
i doubt its the tune since it's been the same for over 5 years and worked perfectly until recently. i'm thinking something mechanical, i just can't pinpoint it. Any ideas? any help would be appreciated.
Old Nov 1, 2024 | 01:53 PM
beaner's Avatar
Tcehing In
Giant boost leak. Probably a popped off coupler. Cap off the compressor inlet and pressurize the system with an air compressor if there's nothing obvious visually.
Old Nov 1, 2024 | 04:16 PM
xsports33's Avatar
thanks for the reply. i need to do a leak test.
but, if it was a big leak why would i make 3-4 psi boost at half throttle and then drop to 0psi at WOT? wouldn't a leak always leak, not just at very high PSI?
Old Nov 1, 2024 | 05:39 PM
smokinlmm's Avatar
What supercharger do you have?
Old Nov 1, 2024 | 06:04 PM
FFDP's Avatar
If you have silicone elbows on the intake, it could be sucking them shut at full throttle.
This just happened on my friends rock crawler. It has a long intake tube routing because of the cramped engine bay of the rock crawler and one of the elbows was being sucked closed at full throttle. With a new elbow now it's got an extra 150hp he said lol.
Old Nov 1, 2024 | 09:04 PM
xsports33's Avatar
Radix MP112
Old Nov 1, 2024 | 10:18 PM
_zebra's Avatar
makes children cry
sounds like a potential soft intake tube collapsing (more vacuum = more restriction)... but it's hard to imagine where'd be a soft tube for that blower on that truck. they're made for each other & have space for days to run all hard piping.
... unless there's something loose near your intake inlet / filter that gets sucked onto it & blocks all your incoming air when the suction gets strong enough.
... or you've got some gnarly belt slip
Old Nov 2, 2024 | 03:25 AM
smokinlmm's Avatar
Wonder if your bypass valve is acting up?
Old Nov 2, 2024 | 10:17 AM
terravast4's Avatar
I agree with FFDP. When I had my MP112 I had one coupling that was being sucked partially closed under WOT. I got some couplings that were lined with aluminum tubing and it fixed the issue. If you are seeing that much belt slip I would imagine black dust everywhere around that blower snout.
Old Nov 2, 2024 | 10:31 AM
_zebra's Avatar
makes children cry
he mentioned recently replacing it
