Looking for a special kind of check valve
Truck Sponsor
Found some low crack pressure valves on McMaster, with cracking pressure of 0.3 psi: 7775K11
Back to your idea, you would want to place the PCV valve between the intake and the catch can or else the air getting sucked into the can from the drain line wouldn't be regulated.
I'm trying to keep the drain line large so it doesn't get clogged, thinking 1/2" or so.
One way check valve I would put close to intake.
How much build up are you getting?
That low check would be nice. That valve would be closed during driving conditions. And if there's enough weight it crack open while not driving.
thompson
01-27-2016 08:11 AM
