Looking for remote mounted Turbo pics...
Old Nov 4, 2007 | 06:13 PM
Stampede4ever's Avatar
Default Looking for remote mounted Turbo pics...
Thinking of doing a rear mounted turbo, but I need some ideals on how to route my tubing for a 4x4. Post pics if you have some.
Thanks.
Old Nov 4, 2007 | 06:20 PM
explorer5.0's Avatar
TOTM: November '07
what truck is it?
Old Nov 4, 2007 | 06:32 PM
BlownChevy's Avatar
blownerator
25 Year Member
http://s7.photobucket.com/albums/y25...STS%20Install/
Old Nov 4, 2007 | 07:05 PM
Yukon 400's Avatar
Please excuse the dirty car.
Sts Turbo
Old Nov 11, 2007 | 11:35 PM
Turbo 6.0's Avatar
Here is a custom remote setup I did on my truck.
Old Nov 12, 2007 | 04:50 PM
tt460's Avatar
Any instrumentation done to determine the effectiveness of an intercooler in that location?
Old Jan 3, 2008 | 02:46 AM
gizzmotk's Avatar
bump
how well does it work?
Old Jan 3, 2008 | 03:15 AM
Yukon 400's Avatar
It seems to work pretty well, intake temps level out at 10 degrees above ambient temps measured before the tb, even in 110+ degree heat over the summer. I thought about adding a scoop on the bottom to help it out at cruising speed, but the idea of it being a trap for rocks and sand on unpaved roads and trails was the deterrent so I only have 2 1200cfm fans on top drawing air through
Old Jan 3, 2008 | 03:23 AM
gizzmotk's Avatar
Did you ever tow with it? is it the same one your selling? What psi where you running?
Old Jan 3, 2008 | 03:36 AM
Yukon 400's Avatar
I have towed my 22' boat to the lake which is goes through a good amount of elevation changes on the way along with a trip from Vegas to Reno it worked fine without much tempreature increase.
It it the same overall and core size as the one on my car, the one on my car has 2.5" inlet and outlets compared to the 3" on the one that I am selling. I was going to install two of them stacked together infront of my dodge ram, until I ran came across a much larger one that I used instead.
My yukon runs around 7.5lbs from 1800rpm and up
