Livernois kit??
Old Feb 13, 2006 | 07:43 AM
Default Livernois kit??
My 2000 silverado has 80000 miles on it. I was thinking of buying the livernois kit. Would adding boost to this engine with the mileage be a problem? Also, what tuning changes would be a must for the initial install? I have HPTuners.
Old Feb 13, 2006 | 11:52 PM
duwem's Avatar
engines just getting broken in man.....does it use any oil between engine changes?
Old Feb 14, 2006 | 06:58 AM
Doesn't use any oil. I have taken very good care of this motor.
Old Feb 14, 2006 | 07:18 AM
Allgonoshow's Avatar
there's a kit in the clasisfieds below
Old Feb 14, 2006 | 07:21 AM
Yeah. That is the one I am thinking of getting. Thanks
Old Feb 14, 2006 | 11:56 AM
kbracing96's Avatar
I built a turbo for my 91 S-10 with 180,000 miles on it, it worked great, even though everyone tried to tell me that 2.8 v-6's where POS's and it would blow up. Put 10,000 hard miles on it before I sold it. Ran good with 6 lbs of boost.
Old Feb 14, 2006 | 01:09 PM
Are most of you guys tuning for boost yourself or having it done? Is the added heat uner the hood going to be a big factor? What kind of power are you guys seeing with the standard kit/stock motor combo? Do you use any kind of boost controllers or anything? I have always been a nitrous guy and I am just starting to research the FI side.
Old Feb 14, 2006 | 02:01 PM
kbracing96's Avatar
I've done all my own tuning on the STS kit with EFILive. Wasn't too hard, as my motor is stock other then the bigger injectors and the turbo. I would wrap the turbo with a blanket and make any heat shield where the headers could be a problem. And also try to keep the intake air sealed to cold air.
Old Feb 14, 2006 | 03:30 PM
I mean the kit is intended for a bolt on application right? I have heard that as little as 5psi boost can really hurt the stock LS1 motor because of the higher compression.
Old Feb 14, 2006 | 03:38 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
People have run as much as 12psi on a stock bottom end with proper tuning. Proper tuning is the key to making your motor last.
