Limit of 44lb injectors?
Old Mar 7, 2008 | 12:09 AM
nonnieselman's Avatar
Default Limit of 44lb injectors?
Hey guys,
Ive been doin some reading and maybe, just maybe one day ill get off 5psi,
I have 44# injectors, right now they are at 86% at 6000 rpms.
I also have a Walbro Intank pump.
How much boost can i up it to on this 6.0 before i run out of injector?
Im shifting it at 5500 btw.
Old Mar 7, 2008 | 12:18 AM
Stoichiometric's Avatar
I think you are not supposed to run them much past 85%. The smaller the injector the longer it must remain open to inject X quantity of fuel in X amount of time(RPM). At a certain point the injector that is too small will continue injecting fuel after the intake valve starts closing resulting in inconsistant fueling.
Old Mar 7, 2008 | 12:21 AM
Ahh.. so basically im maxed out right now.
what about 60#s?
Old Mar 7, 2008 | 12:27 AM
The problem is almost oposite with 60s. The larger high impedence injectors *can* be difficult to tune at idle (low pulsewidth). I haven't read about idle complaints with 60s in a while.
Old Mar 7, 2008 | 12:29 AM
oh ok... well thanks for your help man.. look like ill be sticking with 5psi for awhile... got to pay for this 80E and other stuff...
i have a couple friends that can help me with the tune..
Old Mar 7, 2008 | 12:34 AM
You can stretch your injectors out if you add any Alky kit and run 100% methanol. That is similar cost to upgrading the injectors and makes things more complicated. I'm sure you have a handle on the tuning, just read some of the threads on the EFI forum about idle tuning and tuning for large injectors.
Old Mar 7, 2008 | 12:57 AM
Ive thought about the Meth injection.. but i dont need it anymore complicated than it is.. ive had enough problems with this dang truck so i dont need any thing else.
Im goin to just sit on 5psi for awhile and do some reading and emailing.
i figure 12 seconds at 5psi is respectable....
Old Mar 11, 2008 | 10:32 AM
Gordy M's Avatar
Log your injector duty cycle for the entire run, you will probably find you are under 80% IDC at 5500 rpm's. Also, if you add more boost you might only go over the 85% number for fractions of a second before you shift. Unless you have a dedicated drag truck it doesn't pay to go fight the tuning problems of larger injectors. With good tunning you should be able to get 7-8 lbs of boost and almost 10 lbs with meth. Remember 99.9% of the time you are running at 59 % IDC or less
Old Mar 11, 2008 | 11:28 AM
Whippled 496's Avatar
I agree, but why strain them for even 1% of the time. It only takes 1 lean condition to fry a piston. Better to be safe than sorry. Plus i have been seeing more and more guys running the 60's with no issues idling at all. Hopefully i will be one of them soon.
Old Mar 11, 2008 | 01:34 PM
quicksilverado's Avatar
With meth and 43 lb injectors I ran 12 psi on the old setup. You should be able to run 8 lbs easy, maybe even 10. I'm currently runnig 7.5 psi without meth. Gonna swap the 60s in a few days.
